Use aggregate area ranges to reduce the number of link-state advertisements required within the area. You can also control advertisements.
- Enable OSPF globally.
- Ensure that the port uses an IP address.
- Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
- Select OSPF.
- Select the Area Aggregate tab.
- Select Insert.
- Type the area ID.
- Select the type of link-state database.
- Type the IP address of the network.
- Type the subnet mask.
- Select the effect.
- In AdvertiseMetric, type a cost to advertise for the OSPF area range.
- Select Insert.
Area Aggregate Field Descriptions
Use the data in the following table to use the Area Aggregate tab.
| Name | Description |
| AreaID | Specifies the area in which the address exists. |
| LsdbType | Specifies the LSDB type:
| IP Address | Specifies the IP address of the network or subnetwork indicated by the range. |
| Mask | Specifies the network mask for the area range. |
| Effect | Specifies advertisement methods:
| AdvertiseMetric | Changes the advertised metric cost for the OSPF area range. |
| ExtRouteTag | Specifies the external route tag to be included in NSSA (type-7) LSAs. |
